b1gMail 7.4.1 Beta 1 released
    b1gMail 7.4.1 Beta 1 is now available for download at https://github.com/b1gMail-OSS/b1gMail/releases! It is the first version released under the GPL license. As with every beta version: Don't use for productive use!
    Changes 7.4.0->7.4.1
    • All proprietary graphics replaced by free ones and by Font Awesome
    • Update of libraries: Smarty to 2.6.32, CKEditor to 4.17.1, Font Awesome to 4.7
    • Fax plugin: FPDF to 1.84 and FPDI 2.36. Proprietary FPDI parser library removed.
    • minor bug fixes
    • Optional: conversion to utf8mb4. New installations are always in utf8mb4.
    • Cleanup of code that is only intended for an older PHP version.
    • Support for PHP 8.0 and 8.1 (currently experimental, please test!)
    Update from b1gMail 7.4.0
    Just upload the files. No database specific changes were made. In serverlib delete the file version.inc.php and rename version.default.inc.php to version.inc.php. Alternatively call /setup/update.php. In both cases the setup folder must be deleted afterwards.
    • Before updating, please make a backup of your database and files. No liability for data loss!
    • b1gMail 7.4.1 requires at least PHP 5.4
    • New installation requires at least MySQL / MariaDB 5.5.3
    • After the update please delete your browser cache
    • b1gMail 7.4.1 also contains the PremiumAccount and Fax plugin.
    • If b1gMailServer is used, please restart the queue service after the update and make sure that the latest version is used.
    • The server part of b1gMailServer is currently NOT OpenSource, only the included admin interface.
    • Plugins from ThinkClever GmbH are not compatible with the b1gMail 7.4 version. These must be uninstalled before update.
    • If the b1gMail installation is still running in ISO character set / Latin mode, it is strongly recommended to convert to UTF-8 format.
    • The toolbox is currently not available for the free version. License holders of the former commercial b1gMail version can still use the service, see below for more information.
    • Update notifications are not available
    • Fax plugin: Since the proprietary FPDI parser library is not allowed to be shipped in a GPL project, it was removed with the update of the FPDI class. This removes support for compressed PDF files. If one still needs this, a license must be purchased at https://www.setasign.com/products/fpdi-pdf-parser/pricing/. Alternatively, the last commercial version of the fax plugin can be used if a license was purchased at that time.
    Note for users who previously used the commercial version:
    The service at b1gMail.org are currently not accessible. This includes the toolbox. If you want to use the toolbox from b1gMail.com, you have to add the following to config.inc.php:
    PHP: config.inc.php
    define('B1GMAIL_DLDATE', ''); //Here add dldate
    define('B1GMAIL_LICDOMAIN', ''); //Here add licdomain
    define('B1GMAIL_SIGNKEY', ''); //Here add signkey
    You get these values from serverlib/init.php of the commercial version.
