b1gMailServer 2.8.3304 for b1gMail 7.4.1 is now available for download. b1gMailServer was already released 2023 as OpenSource on GitHub at https://github.com/b1gMail/b1gMailServer.
Important: This b1gMailServer version is only compatible with b1gMail 7.4.0 and 7.4.1. Even if it could work with b1gMail 7.2 and 7.3, we are not tested with this version.
Changes 2.8.3283-> 2.8.3304
- Adaptation of the code so that it can be compiled in a Docker environment with Ubuntu 16
- OSS version of b1gMail 7.4.1 support now: Login with alias forbidden by default
- SMTP smuggling attack Protection
- License check removed. There is no longer a distinction between normal and professional, all functions of the professional version are always available
If you have not already done so, update to b1gMail 7.4.1 or higher.
Please follow the installation instructions on Wiki.
Update from version 2.5/2.6/2.7
If you have not already done so, update to b1gMail 7.4 or higher.
Notes:
- Before update, please update the admin plugin first. b1gMail 7.4.1 have already the latest admin plugin is, but must be deactivated in the plugin beforehand and reactivated after deactivation.
- A compiled version for Linux x64 is available below.
- The documentation can always be viewed in the wiki: https://github.com/b1gMail-OSS/b1gMail/wiki#b1gmailserver
- To use the Autodiscover/Autoconfig function, further steps are required after the update.
- A certificate from Apple is required for Apple Push Support (more information)
SHA-256 values of the file attachments are
- 3a918c194d1557b1b2a20160ec68af8ea466ae7ffc3ff24c7e19143d4243b3c5 BMSAdmin-1.151.bmplugin
- d21116b2a4236b3cb88782645428c0e46103a83c8b886b128f571915bf749a20 b1gmailserver-2.8.3304-x86_64.run
- b6473dd6b1b7be003dc69c48bcfef4eb2e20d21b047ba79024d1c6ac68f72ceb Signature-x64.zip
