b1gMail 7.4.1 Beta 1 is now available for download at https://github.com/b1gMail-OSS/b1gMail/releases! It is the first version released under the GPL license. As with every beta version: Don't use for productive use!
Changes 7.4.1-beta1->7.4.1-beta2
- New feature: Whitelist for maintenance, contributed by @mkleger
- New feature: Custom Sendername in alias
- Updated library: SabreDAV to 3.0.7
- Add removeIP to plugins
- Updated newsPlugin Template for 7.4.1
- Fixed issue #3
- more fixes for PHP 8 and higher
- fixed install script: If you make already a new installation with 7.4.1-beta please change in serverlib/config.inc.php DB_PREFIX to DB_CHARSET
Update from b1gMail 7.4.0 and 7.4.1-beta1
- Before updating, please make a backup of your database and files. No liability for data loss!
- b1gMail 7.4.1 requires at least PHP 5.4
- New installation requires at least MySQL / MariaDB 5.5.3. MySQL 8.x and higher is currently not supported ( except MariaDB ). We recommend MariaDB as Database Engine.
- After the update please delete your browser cache
- b1gMail 7.4.1 also contains the PremiumAccount and Fax plugin.
- If b1gMailServer is used, please restart the queue service after the update and make sure that the latest version is used.
- The server part of b1gMailServer is currently NOT OpenSource, only the included admin interface.
- Plugins from ThinkClever GmbH are not compatible with the b1gMail 7.4 version. These must be uninstalled before update.
- If the b1gMail installation is still running in ISO character set / Latin mode, it is strongly recommended to convert to UTF-8 format.
- The toolbox is currently not available for the free version. License holders of the former commercial b1gMail version can still use the service, see below for more information.
- Update notifications are not available
- Fax plugin: Since the proprietary FPDI parser library is not allowed to be shipped in a GPL project, it was removed with the update of the FPDI class. This removes support for compressed PDF files. If one still needs this, a license must be purchased at https://www.setasign.com/products/fpdi-pdf-parser/pricing/. Alternatively, the last commercial version of the fax plugin can be used if a license was purchased at that time.
