b1gMail 7.5 - Suggestions
    Here you can write suggestions for b1gMail 7.5.
    My wishes:
    • set minimum requirement to PHP8
    • Complete UTF8 encoding, remove support for ISO-8559-1
    • Removal of old updater routines (only one update from 7.4 to 7.5 should be possible, later always the last old version)
    • PLZ city check should be removed or outsourced to a plugin.
    • Update the libraries to the latest versions (SabreDAV, CKEditor, Smarty3).
    • Internationalize country list. My idea: Work with country codes instead of country names and reference them in the language file (or use the ID as a marker). Currently the country list is always in German.
    • Remove individual webdisk icons (who uses it?), better use Font Awesome instead.
