b1gMail 7.4.1 Beta 3 is now available for download at https://github.com/b1gMail-OSS/b1gMail/releases! It is the first version released under the GPL license. As with every beta version: Don't use for productive use!
Changes 7.4.1-beta2->7.4.1-beta3
- New feature: field company and taxid contributed by SLM
- New feature: Edit alias sendername
- New feature: Alias login is disabled by default, user can set if login is allowed for every alias (note: this has no effect on b1gMailServer)
- New feature: deref.php shows a warning, if an external link is clicked (enabled by default, can disabled on admin)
- New feature: favicon show a number, when new emails is coming (commit b497530)
- Organizer can now disabled at group settings
- Add auth plugin: wbb2 and MyBB
- more fixes for PHP 8 and higher
- Updated german plz (commit 8956ce0)
- new template hooks: afterButtons and beforemailSendOptions (commit facf6b3)
- new tool: postfix transport list creator, if you plan to use b1gMail with Postfix Transport (commit 2fbda2e)
- switch to fork awesome (which is compatible with font awesome 4.7, but with more icons. Note: This decision has no impact on later versions, when an upgrade from Font Awesome to the latest one is planned.)
- updated ckeditor to 4.17.2 and Restored show source button
- a lot of small fixes and improvements
Update from b1gMail 7.4.0, 7.4.1-beta1 and 2
- Before updating, please make a backup of your database and files. No liability for data loss!
- b1gMail 7.4.1 requires at least PHP 5.4
- New installation requires at least MySQL / MariaDB 5.5.3. MySQL 8.x and higher is currently not supported ( except MariaDB ). We recommend MariaDB as Database Engine.
- After the update please delete your browser cache
- b1gMail 7.4.1 also contains the PremiumAccount and Fax plugin.
- If b1gMailServer is used, please restart the queue service after the update and make sure that the latest version is used.
- The server part of b1gMailServer is currently NOT OpenSource, only the included admin interface.
- Plugins from ThinkClever GmbH are not compatible with the b1gMail 7.4 version. These must be uninstalled before update.
- If the b1gMail installation is still running in ISO character set / Latin mode, it is strongly recommended to convert to UTF-8 format.
- The toolbox is currently not available for the free version. License holders of the former commercial b1gMail version can still use the service, see below for more information.
- Update notifications are not available
- Fax plugin: Since the proprietary FPDI parser library is not allowed to be shipped in a GPL project, it was removed with the update of the FPDI class. This removes support for compressed PDF files. If one still needs this, a license must be purchased at https://www.setasign.com/products/fpdi-pdf-parser/pricing/. Alternatively, the last commercial version of the fax plugin can be used if a license was purchased at that time.
