• Hi everyone.
    I'm coming to ask some help to resolve Z-push issue. In 2021, I installed Z-push 2.2 version and everything was working very nice. But few month later, things goes wrong and I started investigations. So in the logs, I saw some errors that I want to share with all of you to beg your kindly help.
    I'm using apache, centos 7 and cpanel
    z-push.log
    25/07/2021 21:38:37 [22826] [FATAL] [unknown] FatalException: FixFileOwner: /var/log/z-push must be owned by the nginx/apache/php user instead of root - code: 0 - file: /usr/share/z-push/lib/utils/utils.php:895
    15/07/2022 21:01:22 [ 7654] [FATAL] [unknown] FatalException: FixFileOwner: /var/log/z-push must be owned by the nginx/apache/php user instead of root - code: 0 - file: /usr/share/z-push/lib/utils/utils.php:895
    15/07/2022 21:01:22 [ 7654] [ INFO] [unknown] User-agent: 'unknown'
    15/07/2022 21:01:22 [ 7654] [FATAL] [unknown] Exception: (FatalException) - FixFileOwner: /var/log/z-push must be owned by the nginx/apache/php user instead of root
    15/07/2022 21:01:22 [ 7654] [ INFO] [unknown] cmd='' memory='2.32 MiB/4.00 MiB' time='0.04s' devType='' devId='' getUser='unknown' from='UNKNOWN' idle='0s' version='2.3.9' method='unknown' httpcode='500'
    z-push-error.log
    Thanks a lot for your help
    Einmal editiert, zuletzt von zamana (16. Juli 2022 um 17:44)
    on which user b1gmail is running? how you set the error log file (see configuration file)? It says /var/log/z-push must be owned by nginx/apache or php. You have to look which user is running the http server.
  • Hi Sebijk,
    Thanks a lot to reply to my request.
    I write the
    Alias /Microsoft-Server-ActiveSync /usr/share/z-push/index.php
    link the the right httpd.conf file ; /usr/local/apache/conf/httpd.conf in cpanel
    but the prompt not display when i invoke this link https://server-domain.xy/Microsoft-Server-ActiveSync
    Don't know what's wrong... It's working before..
    But the good news, when I open the log, I didn't get any error
