    Note for users who previously used the commercial version:
    The service at b1gMail.org are currently not accessible. This includes the toolbox. If you want to use the toolbox from b1gMail.com, you have to add the following to config.inc.php:
    PHP: config.inc.php
    define('B1GMAIL_DLDATE', ''); //Here add dldate
    define('B1GMAIL_LICDOMAIN', ''); //Here add licdomain
    define('B1GMAIL_SIGNKEY', ''); //Here add signkey
    You get these values from serverlib/init.php of the commercial version.
    b1gMail 7.4.1 Beta 1 is now available for download at https://github.com/b1gMail-OSS/b1gMail/releases! It is the first version released under the GPL license. As with every beta version: Don't use for productive use!
    Changes 7.4.1-beta1->7.4.1-beta2
    • New feature: Whitelist for maintenance, contributed by @mkleger
    • New feature: Custom Sendername in alias
    • Updated library: SabreDAV to 3.0.7
    • Add removeIP to plugins
    • Updated newsPlugin Template for 7.4.1
    • Fixed issue #3
    • more fixes for PHP 8 and higher
    • fixed install script: If you make already a new installation with 7.4.1-beta please change in serverlib/config.inc.php DB_PREFIX to DB_CHARSET
    Update from b1gMail 7.4.0 and 7.4.1-beta1
    • Before updating, please make a backup of your database and files. No liability for data loss!
    • b1gMail 7.4.1 requires at least PHP 5.4
    • New installation requires at least MySQL / MariaDB 5.5.3. MySQL 8.x and higher is currently not supported ( except MariaDB ). We recommend MariaDB as Database Engine.
    • After the update please delete your browser cache
    • b1gMail 7.4.1 also contains the PremiumAccount and Fax plugin.
    • If b1gMailServer is used, please restart the queue service after the update and make sure that the latest version is used.
    • The server part of b1gMailServer is currently NOT OpenSource, only the included admin interface.
    • Plugins from ThinkClever GmbH are not compatible with the b1gMail 7.4 version. These must be uninstalled before update.
    • If the b1gMail installation is still running in ISO character set / Latin mode, it is strongly recommended to convert to UTF-8 format.
    • The toolbox is currently not available for the free version. License holders of the former commercial b1gMail version can still use the service, see below for more information.
    • Update notifications are not available
    • Fax plugin: Since the proprietary FPDI parser library is not allowed to be shipped in a GPL project, it was removed with the update of the FPDI class. This removes support for compressed PDF files. If one still needs this, a license must be purchased at https://www.setasign.com/products/fpdi-pdf-parser/pricing/. Alternatively, the last commercial version of the fax plugin can be used if a license was purchased at that time.
    Kannst du das auf frisch installierten Ubuntu 18.04 oder höher testen (kein Upgrade von 16.04)? Bei mir klappt es ohne Probleme.
    Die SHA256-Checksumme bei /opt/b1gmailserver/b1gmailserver ist bei dir auch cea3bdded0e46a05d1b3e054424b66e4da8c49ba46fbccd460f00ef7758367af oder?
    Evtl. Hardwaredefekte (wie z.B. RAM) kannst du bei dir ausschließen oder?
    Aber was ich dir wärmstens ans Herz legen möchte ist nicht mehr Ubuntu 16.04 zu nehmen, sondern gleich auf eine aktuelle zu gehen.
    End of Standard Support: April 2021
    Ubuntu 16.04 wird schon noch im Rahmen von ESM unterstützt, ist allerdings anmeldepflichtig.
    b1gmailserver-2.8.3286-x86_64
    Ich hatte 16.04 genommen, da die Anleitungen für 16.04 waren. Ich hatte gedacht (und das ist wahrscheinlich das Problem ^^ ), dass neuere Ubuntu Versionen mit B1G nicht kompatibel sind...
    Wenn neuere Versionen nicht gehen, dann hätten sich allerdings schon einige im Forum gemeldet.
    Daher auch meine Empfehlung: Stets aktuelle Versionen nutzen (allein schon aus Sicherheitsgründen), wenn nicht zwingende Gründe dagegen stehen.
    b1gMailServer liefert eigene Bibliotheken mit (wie man es schön mit ldd sieht), damit es keine Probleme mit Abhängigkeiten gibt. Um nachzuschauen, weshalb ein Segmentation fault ausgelöst wird, müsste b1gmailserver mit Debug-Symbolen kompiliert werden: https://dzone.com/articles/detec…faults-in-linux . Bringt halt aber nichts, wenn der Code zurzeit noch Closed Source ist.
    Welchen Vorteil hat die Verwendung von b1gZip statt dem PHP-eigenen?
    Wenn du das zip-Modul meinst: Das müsste man herausfinden, z.B. durch Performancetests. Als b1gZIP das erste Mal erschien, war das PHP Modul zip nur als PECL-Erweiterung verfügbar und konnte nur Archive lesen, nicht aber schreiben oder welche erzeugen. Aber es wurde ständig weiterentwickelt und mit PHP 5.2 zum Standard. Rein funktionell her ist man mit php-zip besser bedient.
    php-zip nutzt libzip als Bibliothek, b1gzip hingegen ZipArchive von Artpol. Sollte sich die ZipArchive-Bibliothek als robuster und performanter als libzip herausstellen, wäre eine Weiterentwicklung von b1gzip um weitere Funktionen, die die ZipArchive-Bibliothek bietet, interessant.
    Gegenüber der b1gMail zip.class.php Implementation hat b1gzip einen Geschwindigkeitsvorteil, da diese PHP-Klasse eine eigene Implementation ist, die nicht php-zip nutzt. Das hat man wohl so gemacht, damit man die Kompatibilität zu PHP 4 nicht aufgeben musste.
    2003 wurde b1gZIP veröffentlicht. Es nutzt die ZipArchive-Bibliothek von Artpool Software. b1gZIP dient zum Erstellen von Zip-Archiven und seit der Veröffentlichung hat sich nichts geändert. In b1gMail kommt b1gZIP vorrangig zum Erstellen von ZIP-Archiven in Einsatz (falls Modul existiert), bevor es auf die Zip-Klasse zurückgreift.
    Sourcecode inkl. Anleitung zum Kompilieren findet sich hier: https://github.com/b1gMail-OSS/php-b1gzip
    Ich habe heute die Erweiterung an PHP7 und 8 angepasst, so dass sie sich dort auch kompilieren und ausführen lässt.
    Was interessant wäre, wenn jemand mal die Zeit hätte, die Performance von b1gZip mit der vom php-zip oder anderen PHP Zip-Klassen zu vergleichen.
    Danke, ich schau es mir an und werde es dann einbauen.
    Man merkt schon, wie schwierig es ist, base64-kodierte Strings zu vergleichen, hab mal aus dem Post die Funktion übernommen, damit man besser vergleichen kann: https://stackoverflow.com/questions/6672…rogrammatically
    b1gMail comes by default with German and English. All other languages are at this repository: https://github.com/b1gMail-OSS/b1gMail-languages
    Currently in this repo:
    French (only user interface, thanks to zamana for the Translation)
    German (informal, incomplete from daniela)
    Romanian (incomplete, from Radu)
    Russian (incomplete, from atmark)
    How I can contribute?
    Just fork the repository and add your translation. After make a pull request.
    PHP: config.inc.php
    Changes 7.4.0->7.4.1
    • All proprietary graphics replaced by free ones and by Font Awesome
    • Update of libraries: Smarty to 2.6.32, CKEditor to 4.17.1, Font Awesome to 4.7
    • Fax plugin: FPDF to 1.84 and FPDI 2.36. Proprietary FPDI parser library removed.
    • minor bug fixes
    • Optional: conversion to utf8mb4. New installations are always in utf8mb4.
    • Cleanup of code that is only intended for an older PHP version.
    • Support for PHP 8.0 and 8.1 (currently experimental, please test!)
    Just upload the files. No database specific changes were made. In serverlib delete the file version.inc.php and rename version.default.inc.php to version.inc.php. Alternatively call /setup/update.php. In both cases the setup folder must be deleted afterwards.
    PHP: config.inc.php
    define('B1GMAIL_DLDATE', ''); //Hier dldate eintragen
    define('B1GMAIL_LICDOMAIN', ''); //Hier licdomain eintragen
    define('B1GMAIL_SIGNKEY', ''); //Hier signkey eintragen
    Die ersten drei Angaben holt man sich aus der serverlib/init.php aus der kommerziellen Version.
