    b1gMail 7.4.2 will not support the old ISO character set or latin1 anymore. You must convert to utf8 first.
    b1gMail 7.4.2 Release Candidate 2 is now available for download at https://github.com/b1gMail-OSS/b1gMail/releases! With every pre-release: use with own caution! If there is no any faulty reports, we will release the final release in 1-2 months.
    Changes 7.4.1->7.4.2-rc2
    • add french language (user frontend only), thanks to zamana for providing this.
    • fix undefined indexes and variables
    • fix issues with PHP 8.4 and SMS send on PHP 8.
    • admin template: fix some wrong labels
    • jQuery updated to 3.7.1
    • jQuery Mobile updated from 1.3.0 to 1.4.5 (also new theme for mobile interface)
    • bootstrap updated to 3.4
    • add addalias plugin from dotaachen with 7.4.2 compatibility and improvements
    • add new plugins: Log failed logins and Logout Notice
    • add safelink decoder and utm remover
    • Upgrade to Smarty5
    • new responsive ACP template, contributed by ManDal
    • new captcha provider: hCaptcha, contributed by ManDal
    • webdiskicons replaced by Fork Awesome
    • fix mislabelled field: inv_company
    • other small bug fixes
    Known issues (since 7.4.1):
    • memcached is currently not working in PHP 8
    • mysql 8 and higher not supported yet
    • invoice generator not work yet
    This version is fully compatible with the latest PHP version.
    Update from b1gMail 7.4.0 and 7.4.1
    upload the files. After call /setup/update.php. Alternatively delete in serverlib the file version.inc.php and rename version.default.inc.php to version.inc.php and call tools/db_sync.php. In both cases the setup folder must be deleted afterwards. If you update from b1gMail 7.4.0 or earlier, make sure you have a backup of serverlib/init.inc.php.
    Notes about former commercial version: Please read also b1gMail 7.4.1 released
    • Before updating, please make a backup of your database and files. No liability for data loss!
    • b1gMail 7.4.2 requires at least PHP 7.2.
    • New installation requires at least MySQL / MariaDB 5.5.3. MySQL 8.x and higher is currently not supported ( except MariaDB ). We recommend MariaDB as Database Engine.
    • After the update please delete your browser cache
    • b1gMail 7.4.2 also contains the PremiumAccount and Fax plugin.
    • If b1gMailServer is used, please restart the queue service after the update and make sure that the latest version is used.
    • If you want use the new features also on b1gMailServer, please upgrade your b1gMailServer to the OSS version: https://www.github.com/b1gMail/b1gMailServer
    • Plugins from ThinkClever GmbH are now Open Source, but not all plugins is compatible. Check here to check if the plugin is compatible with 7.4.2. If you use CleverMailEncryption, there is also a compatible version to 7.4.2 in the provided link.
    • If the b1gMail installation is still running in ISO character set / Latin mode, you are required to convert to UTF-8 format, otherwise you could get charset problems.
    • This version is shipped on the latest CKEditor4 version which reached its end-of-life in June 2023. There will no more any updates. If you want receive updates for CKEditor, you can use the commercial LTS version of CKEditor4 or upgrade to CKEditor 5. See https://ckeditor.com/docs/ckeditor5…ckeditor-4.html for migration guide.
    • The toolbox is currently not available. License holders of the former commercial b1gMail version can still use the service, see below for more information. You find the source code at https://www.github.com/b1gMail/BMToolbox
    • Update notifications are not available
    • Fax plugin: Since the proprietary FPDI parser library is not allowed to be shipped in a GPL project, it was removed with the update of the FPDI class. This removes support for compressed PDF files. If one still needs this, a license must be purchased at https://www.setasign.com/products/fpdi-pdf-parser/pricing/. Alternatively, the last commercial version of the fax plugin can be used if a license was purchased at that time.
    UNC hat freundlicherweise seine Plugins für b1gMail 7 wiederveröffentlicht, diesmal als Open Source: https://github.com/pencil/unc-b1gmail-plugins . Vielen Dank dafür.
    Ich hab es direkt geforkt und für CleverMailEncryption erste Anpassungen für b1gMail 7.4.1 vorgenommen: https://github.com/Sebijk/unc-b1gmail-plugins . Aktuell funktioniert das ver/entschlüsseln von E-Mails, nur bestehende unverschlüsselte E-Mails vor der Installation klappt noch nicht.
    Welche Plugins sind es?
    BetterMailSearch
    BetterQuota
    CleverBranding
    CleverCron
    CleverSupportSystem
    CleverTimeZone
    Alle sind bis einschließlich b1gMail 7.3.0 kompatibel.
    Ja, es bedeutet nur dass es auf Ubuntu 22.04 kompiliert wurde, aber höher geht immer. Das ist wegen CMake (musste glaub ich ab 3.18 sein) geschuldet. Auf alten Systemen führt es dazu, dass nicht ausgeführt werden kann und meldet dann version `GLIBC_2.33' not found. Also bei Debian geht es erst ab Version 12.
    Evtl. sollte bei Docker die Buildumgebung auf Debian 11 gesetzt werden, damit es auch noch da läuft. da ist cmake auf 3.18.4.
    Kannst du uns eventuell nen Tipp geben, was am 2fa-Plugin und ggfls. noch an der mobilen Version angepasst werden muss damit das funktioniert? Geht ja nur ums Login. Die Aktivierung soll weiterhin nur im UCP möglich sein.
    Dann wäre das System zumindest ein Stück weit sicherer. Wäre echt toll..
    Ein Hinweis befindet sich in der kommenden umgeschriebenen Logout Hinweis Plugin: https://codeberg.org/b1gMail/b1gMai…weis.plugin.php
    lt. gängige Rechtssprechung muss ein Ablehnen von nicht notwendige Cookies möglich sein. Für den zwingenden technischen Betrieb (z.B. Sitzungs-Cookies) ist keine Einwilligung erforderlich.
