- Offizieller Beitrag
b1gMail 7.4.1 Release Candidate 1 is now available for download at https://github.com/b1gMail-OSS/b1gMail/releases! It is the first version released under the GPL license. With the first release candidate we think b1gMail is stable enough, but with every pre-release: use with own caution! If there is no any faulty reports, we will release the final release in 1-2 months.
Changes 7.4.1-beta4->7.4.1-rc1
- Fix a lot of undefined index and variables
- remove obsolete code with safe_mode
- updated CKEditor to 4.22.1
- compatiblity with latest smarty 3 and 4 and updated shipped Smarty library to 3.1.48
- updated FPDI to 2.5.0 and fPDF to 1.86
- Ported some changes from MBuchalik fork
- add new filter in users search: sendername
- Database Struct: switched to json instead serialize + base64
- for devs: added a docker template in repository
This version is fully compatible with the latest PHP 8.2 version.
There may a small low undefined index and variables warning. Please help to find the last issues and report this to us, to fix this. Please note: Also third party plugins could cause an undefined index and variables warning, since mostly are not tested with PHP 8. Please report these errors to the plugin developer or fix yourself.
Update from b1gMail 7.4.0 and 7.4.1-beta
- Before updating, please make a backup of your database and files. No liability for data loss!
- b1gMail 7.4.1 requires at least PHP 5.4
- New installation requires at least MySQL / MariaDB 5.5.3. MySQL 8.x and higher is currently not supported ( except MariaDB ). We recommend MariaDB as Database Engine.
- After the update please delete your browser cache
- b1gMail 7.4.1 also contains the PremiumAccount and Fax plugin.
- If b1gMailServer is used, please restart the queue service after the update and make sure that the latest version is used.
- If you want use the new features also on b1gMailServer, please upgrade your b1gMailServer to the OSS version: https://www.github.com/b1gMail/b1gMailServer
- Plugins from ThinkClever GmbH are not compatible with the b1gMail 7.4 version. These must be uninstalled before update.
- If the b1gMail installation is still running in ISO character set / Latin mode, it is strongly recommended to convert to UTF-8 format.
- This version is shipped on the latest CKEditor4 version which reached its end-of-life in June 2023. There will no more any updates. If you want receive updates for CKEditor, you can use the commercial LTS version of CKEditor4 or upgrade to CKEditor 5. See https://ckeditor.com/docs/ckeditor5…ckeditor-4.html for migration guide.
- The toolbox is currently not available. License holders of the former commercial b1gMail version can still use the service, see below for more information. You find the source code at https://www.github.com/b1gMail/BMToolbox
- Update notifications are not available
- Fax plugin: Since the proprietary FPDI parser library is not allowed to be shipped in a GPL project, it was removed with the update of the FPDI class. This removes support for compressed PDF files. If one still needs this, a license must be purchased at https://www.setasign.com/products/fpdi-pdf-parser/pricing/. Alternatively, the last commercial version of the fax plugin can be used if a license was purchased at that time.
