b1gMailServer 2.8.3305 released
    b1gMailServer 2.8.3304 for b1gMail 7.4.1 is now available for download. b1gMailServer was already released 2023 as OpenSource on GitHub at https://github.com/b1gMail/b1gMailServer.
    Important: This b1gMailServer version is only compatible with b1gMail 7.4.0 and 7.4.1. Even if it could work with b1gMail 7.2 and 7.3, we are not tested with this version.
    Changes 2.8.3304-> 2.8.3305
    • imap: Fix length calculations for partial retrievals (#18)
    The update is potentially security-relevant and should therefore be installed as soon as possible.
    If you have not already done so, update to b1gMail 7.4.1 or higher.
    Please follow the installation instructions on Wiki.
    Update from version 2.5/2.6/2.7
    If you have not already done so, update to b1gMail 7.4 or higher.
    Notes:
    • Before update, please update the admin plugin first. b1gMail 7.4.1 have already the latest admin plugin is, but must be deactivated in the plugin beforehand and reactivated after deactivation.
    • A compiled version for Linux x64 is available below.
    • The documentation can always be viewed in the wiki: https://github.com/b1gMail-OSS/b1gMail/wiki#b1gmailserver
    • To use the Autodiscover/Autoconfig function, further steps are required after the update.
    • A certificate from Apple is required for Apple Push Support (more information)
    • SHA-256 values of the file attachments are
