b1gMail 7.4.2 Release Candidate 3 released
    b1gMail 7.4.2 Release Candidate 3 is now available for download at https://github.com/b1gMail-OSS/b1gMail/releases! With every pre-release: use with own caution! If there is no any faulty reports, we will release the final release.
    Changes 7.4.2rc2->7.4.2-rc3
    • update smarty to 5.8.0
    • extension zip now standard for create zip files
    • fix white email preview on mozilla based browsers
    • add simple login rate limit
    • fix MySQL function DEFAULT values CURRENT_TIMESTAMP
    • security fix for admin login (use password_hash for admin passwords + cookie session lock on admin)
    • BMS admin plugin: Add DNSBL condition field
    • update FPDI to 2.6.4
    • other small fixes
    Known issues (since 7.4.1):
    • memcached is currently not working in PHP 8
    • mysql 8 and higher not supported yet
    • invoice generator not work yet
    This version is fully compatible with the latest PHP version.
    Update from b1gMail 7.4.0 and 7.4.1
    upload the files. After call /setup/update.php. Alternatively delete in serverlib the file version.inc.php and rename version.default.inc.php to version.inc.php and call tools/db_sync.php. In both cases the setup folder must be deleted afterwards. If you update from b1gMail 7.4.0 or earlier, make sure you have a backup of serverlib/init.inc.php.
    Notes about former commercial version: Please read also b1gMail 7.4.1 released
    • Before updating, please make a backup of your database and files. No liability for data loss!
    • b1gMail 7.4.2 requires at least PHP 7.2.
    • New installation requires at least MySQL / MariaDB 5.5.3. MySQL 8.x and higher is currently not supported ( except MariaDB ). We recommend MariaDB as Database Engine.
    • After the update please delete your browser cache
    • b1gMail 7.4.2 also contains the PremiumAccount and Fax plugin.
    • If b1gMailServer is used, please restart the queue service after the update and make sure that the latest version is used.
    • If you want use the new features also on b1gMailServer, please upgrade your b1gMailServer to the OSS version: https://www.github.com/b1gMail/b1gMailServer
    • Plugins from ThinkClever GmbH are now Open Source, but not all plugins is compatible. Check here to check if the plugin is compatible with 7.4.2. If you use CleverMailEncryption, there is also a compatible version to 7.4.2 in the provided link.
    • If the b1gMail installation is still running in ISO character set / Latin mode, you are required to convert to UTF-8 format, otherwise you could get charset problems.
    • This version is shipped on the latest CKEditor4 version which reached its end-of-life in June 2023. There will no more any updates. If you want receive updates for CKEditor, you can use the commercial LTS version of CKEditor4 or upgrade to CKEditor 5. See https://ckeditor.com/docs/ckeditor5…ckeditor-4.html for migration guide.
    • The toolbox is currently not available. License holders of the former commercial b1gMail version can still use the service, see below for more information. You find the source code at https://www.github.com/b1gMail/BMToolbox
    • Update notifications are not available
    • Fax plugin: Since the proprietary FPDI parser library is not allowed to be shipped in a GPL project, it was removed with the update of the FPDI class. This removes support for compressed PDF files. If one still needs this, a license must be purchased at https://www.setasign.com/products/fpdi-pdf-parser/pricing/. Alternatively, the last commercial version of the fax plugin can be used if a license was purchased at that time.
    b1gMail 7.4.2 will not support the old ISO character set or latin1 anymore. You must convert to utf8 first.
  • Sebijk 2. Juni 2026 um 11:56
    Hat das Thema freigeschaltet.
  • Sebijk 6. Oktober 2026 um 09:08
    Hat den Titel des Themas von „b1gMail 7.4.3 Release Candidate 2 released“ zu „b1gMail 7.4.2 Release Candidate 3 released“ geändert.
