b1gMail 7.4.1 Beta 4 is now available for download at https://github.com/b1gMail-OSS/b1gMail/releases! It is the first version released under the GPL license. As with every beta version: Don't use for productive use!
Changes 7.4.1-beta3->7.4.1-beta4
- New feature: add FileHandlerMobile - This allow to use plugins in mobile interface
- Removed: koobi7 and jfchat plugin (they are obsolete)
- a lot of fixes for PHP 8 and higher
- Disabled: memcache, if using PHP 8 and higher. (if you need this, please contribute your code changes to get work)
- Updated german, austria and switzerland city codes. Added one city code database for Sri Lanka
- responsive widgets + template fixes contributed by SLM)
- add dnsbl and reglock check for non logged in users in AvailableCheck
- change structure because of php-bug #10002 on database.struct.php
- updated ckeditor to 4.20.1
- updated fpdf to 1.85
- use CharSetDecode on the rest since utf8_decode and utf8_encode is deprecated in PHP 8.2
- Fix an empty url in deref.php
- a lot of small fixes and improvements
This version is fully compatible with the latest PHP 8.2 version.
Its also the last beta version if there are no any serious fault. There may a low undefined index and variables warning. Please help to find the last issues and report this to us, to fix this. Please note: Also third party plugins could cause an undefined index and variables warning, since mostly are not tested with PHP 8. Please report these errors to the plugin developer or fix yourself.
Update from b1gMail 7.4.0, 7.4.1-beta1 and 2
- Before updating, please make a backup of your database and files. No liability for data loss!
- b1gMail 7.4.1 requires at least PHP 5.4
- New installation requires at least MySQL / MariaDB 5.5.3. MySQL 8.x and higher is currently not supported ( except MariaDB ). We recommend MariaDB as Database Engine.
- After the update please delete your browser cache
- b1gMail 7.4.1 also contains the PremiumAccount and Fax plugin.
- If b1gMailServer is used, please restart the queue service after the update and make sure that the latest version is used.
- If you want use the new features also on b1gMailServer, please upgrade your b1gMailServer to the OSS version: https://www.github.com/b1gMail/b1gMailServer
- Plugins from ThinkClever GmbH are not compatible with the b1gMail 7.4 version. These must be uninstalled before update.
- If the b1gMail installation is still running in ISO character set / Latin mode, it is strongly recommended to convert to UTF-8 format.
- The toolbox is currently not available. License holders of the former commercial b1gMail version can still use the service, see below for more information. You find the source code at https://www.github.com/b1gMail/BMToolbox
- Update notifications are not available
- Fax plugin: Since the proprietary FPDI parser library is not allowed to be shipped in a GPL project, it was removed with the update of the FPDI class. This removes support for compressed PDF files. If one still needs this, a license must be purchased at https://www.setasign.com/products/fpdi-pdf-parser/pricing/. Alternatively, the last commercial version of the fax plugin can be used if a license was purchased at that time.
